Looking to filter data on a dashboard that utilizes OpenTelemetry metrics. There are a few dimensions that are available, which can be used to filter on a host or environment. Is there an entity selector or some other way to add rules to map these custom metrics to a management zone?
Hi @RishiSuthar
You can use tagging rules to tag the metrics and then apply these tags within both Management Zones (MZ) and filters. This allows you to directly target metrics for the relevant services.
