Mapping understanding
I am new to Dynatrace , working on Oracle and I want to know the below:
What is the mapping of
Dashboards   >> Metric Key >> Metric  Event >> Alerting Profile >> XMatter Integration.
Also, I can see some oracle related events but not the keys. For example:
Metric Key event:  com.dynatrace.extension.sql-oracle.dataguard.archiveDestErrStatus
How can I add this metric key, its not visible.
Is it applicable to Oracle RDS Read Replica or RDS  Custom?
Is extension configured to a Dataguard Oracle database already?
If yes, you should be able to see that metric.
Best regards
