MCP Server Challenge entry #3: Automating Site Reliability Reporting & Performance Governance using Dynatrace APIs
This post is an answer to the MCP Server Challenge :robot:‌
Overview:
In digital platform, maintaining visibility into site uptime, performance, and incident impact is critical. This use case demonstrates how to use Dynatrace APIs to build an automated performance reporting.
Problem Statement:
Initially, Weekly reports were manually created, consuming significant time ; No unified way to track MTD/YTD uptime trends ; Difficult to correlate incidents with performance degradation.
Solution Overview:
Using Dynatrace APIs, created a workflow that:
* Extracts metrics, events, and uptime data
* Processes and aggregates them
* Generates automated weekly performance reports
Implementation:
1. Data Extraction via APIs:
Problems API → Incident details (severity, duration, impacted services)
Metrics API → Response time, Apdex, custom KPIs
Synthetic API → Availability & uptime data
RUM API → User experience metrics
2. Converted raw data into business-relevant metrics
Extract availability metrics via Metrics API
Convert data points (1/0) into uptime %
Aggregate across weekly and MTD views
Correlate with Problems API for incident insights
3. Data Processing & Aggregation
Automated scripts process API data
Aggregated into: Weekly summaries ; MTD/YTD rollups
Hello, @rameshkumar_ram!
Thank you for preparing this topic, it looks interesting! Could you drop a comment in the main challenge thread to cross-link your topic and make sure it won’t by missed by anyone?
Thank you!
Hi. Can you share an example report? That would help a lot to understand the value of this use case
