When analyzing Processes memory consumption on a VM host, the graph’s Y axis is scaled to the VM’s total memory - for instance, 0B to 20GB. However, I want to analyze the memory consumption growth of a specific process, which usually consumes only less than 1GB. Dynatrace currently doesn’t offer a way of scaling the graph to a specific process scale (0B to 1GB, for instance). This makes it very hard to check for memory leaks of specific processes.
You can do it in Custom Graphs. Use Process Memory, that should be what you are looking for.
