Message Queue (MQ) channels setup for monitoring
Hi Team,
We are in urgent need for (MQ) message queue/channels setup for monitoring across MQ server instances.
Could you please guide me with DDU requirement and capabilities?
Below are the details
  • 119 message queue/channels
  • 11 MQ server instances (6 prod MQ apps and 5 non-prod MQ apps)
Thanks&Regards
Srinivas
This is a great support Doc on DDUs and the consumption of them per entity. Extending Dynatrace (Davis data units) — Dynatrace Docs I highly recommend reaching out to your account rep as well.
