Metric API POST limit
Hi all,
I’m using the metrics api on Dynatrace Managed from a plugin and have to post a quite large number of metrics - like 90K lines on a test env so that’s gonna get worse when I go to prod.
Found that there seems to be a limit on the amount of data I can send with a single post. Burt I can’t find it in the docs.
Any idea?
cheers,
Torsten
Hi @TorstenHellwig
Its 1MB / Payload:
Metrics API - POST ingest data points - Dynatrace Docs
Bests
Michal
Ok, need new glasses probably. :wink: Thank you Michal!
@TorstenHellwig : The Python 2.0 SDK should split automatically by 1000 lines your message to avoid overload :
