Help me out with a metric event alert please, it’s a simple count metric, but I’m getting frustrated about it.
I’m trying on Settings/Anomaly detection/Metric events
I want to enable an alert via mail if, in a 6-minute period, the incoming data is more than 20 for 2 minutes, but if the data is below 20 again after the alert, for 2 minutes, then another email will come saying that the problem is solved.
My problem is I tried everything: Treshold, Violating samples, sliding samples, dealerting samples, it’s just not giving me the correct behavior.
First of, the minimum sample value for de-alerting is 3, so you can trigger an alert when count is higher than 20 for 2 min in 6, but the problem solving will be set if lower than 20 for 3 min in 6.
For this example I am using the builtin metric for service request count, and filtering for one single service. So the data is coming every 1 minute. The calls to my service is being getting every one minute.
Ye its worked, i did the same way before, as in your screen, the problem was the “Alert on missing data” slide was on.
Thank you
Let me ask here another of the almost same problem. In this case i should get a warning when for 2 minutes there is no data on a 5 minute period. What im missing here?
The alerting on missing data, by default, will alert you when no data is seen in previous minute, it does not follow the sampling information you set for threshold validation.
I have recorded a solution for this in our Dynatrace Tips & Trics first session,
Check this out and let me know if it works. In your case, you can try the rollup transformation for this case.
