Metric for the number of TCP connections per process
Hello, we are looking to have the number of TCP connections on a particular process in order to put an alert when it exceeds the number of user connections For example On port 2020 the process has a connection limit of 500 people Is there an industrial way to put an alert on Dynatrace
Regards
There is no metric for this out of the box. You can use a custom OneAgent Extension to add the metric and specify thresholds.
