Metric Ingestion - tuple of response time values
Good afternoon,
regarding ingesting custom metrics, I’m evaluating best options on how to ingest the data.
In the specific case I’m recording different response time values for a single click and I’d like to have it in a single metric.
The metric should record 3 types of Response Time:
a. Overall Duration
b. System B Duration
c. System C Duration
a = b+c
Is there a way to send this data as a single metric and then split by (dimension) a, b or c so I can have a final result similar to this?
Or should I push a different metric for each of the values?
Regards
Hey Buccellato,
You can ingest all the data points on a single metric key and split by a common dimension as seen below.
If you are only ingesting system b and c and want to do the calculation in Dynatrace that would look something like this.
Hope this helps!
Good morning @Fin_Ubels ! Thank you for replying :slightly_smiling_face:
What is less clear from my point of view is the following.
Here collect mechanism will collect in one go the a,b,c values and push it to Dynatrace:
Those three values should be in three different metrics or can I create a single metric which then can be split by the values? (a little bit like when you have a Synthetic Total Duration but then you can split the total duration by each event contributing)
If I understand your example correctly I can create a metric:
response.time.overall.duration(which is the tota rt a), dim1=b(which is the partial rt from b) dim2=c(which is the partial rt from c) 19070
Regards
