Metrics as Variables
Hi all,
I am creating a dashbord for capacity management but I would like the metric to be selectable by a variable.
I currently have several variables created that allow me to filter by host entity tags and variables that allow me to select the metric type (avg, max, min). The problem I am having is when trying to use the variables to select the metric.
I have a variable ($Metric) that contains:
  • dt.host.cpu.usage
  • dt.host.memory.usage
I want to use that variable in a simple DQL for example:
timeseries usage = percentile(dt.host.cpu.usage, 95, rollup: avg), by:{dt.entity.host}, from: -7d | limit 2
That is:
timeseries usage = percentile($Metric, 95, rollup: avg), by:{dt.entity.host}, from: -7d | limit 2
When doing so I get an error: “The parameter has to be a metric key.” “queryString“: ‘timeseries usage = percentile(\’dt.host.cpu.usage\”, 95, rollup: \“avg”), by:{dt.e…
I understand that the problem is how to parse the value of the variable to the query, is there any way to do it?
Thanks a lot for your time
Victor
Hi
You should try using the “:noquote”  option for variable replacement like this :
timeseries usage = percentile($Metric:noquote, 95, rollup: avg), by:{dt.entity.host}, from: -7d | limit 2
Works :vulcan_salute:,
Thanks a lot
Victor
