Hey guys,
It’s possible to get metrics from monitored database like Oracle, Postgre using Grail?
Today we are using third party extension to run queries and get data but for some reason it is not fetching it correctly.
Thanks!!
Hey guys,
Thanks!!
If you have extensions that monitor your databases you can fetch them by using Metric API. With Grail you can currently fetch only built-in metrics.
Best Regards,
Mateusz
Hi Mateusz,
is there any plan to send extension metrics to Grail ? near future ?
Thanks for your answer
