Micrometer metrics dashboard
Hello - I would like to check if there is any micrometer metrics dashboard that I can use/import ?
Not that I am aware of - but you might find some out there in GITHUB etc.. Send Micrometer metrics to Dynatrace — Dynatrace Docs
Hey,
I have a few dashboards I can share with you! I’ve removed internal identifiers from the JSON so you will have to edit the payload before importing.
This dashboard includes the following spring metrics: executor,jdbc,hikaricp, and httpcomponents
pooledResourcesSpringMetrics.txt (225 KB)
Thanks for Sharing @Nick-Montana 😁
