Migrate Dynatrace Managed with existing IP address
I use Dynatrace Managed version 1.246 also using Rhel 7.8 and I’m going to upgrade Dynatrace Managed server to 1.248. but Dynatrace Managed 1.248 only support rhel 7.8 above. so I decided to migrate Dynatrace Managed server to new installation rhel 8.x with existing IP address. is it possible? If yes then do you have any documentation about it?
Really need your help guys.
Putri
Dear @bputri
Did you get a chance to go through the below documentation:
Migrate a cluster
Babar
