Anybody here tried migrating some Application settings from one env. to the other using API’s? I’m trying to figure out how I could do this, but after looking throguh the community and API definition, I cannot find a schema specifically for web config. Any ideas? Is this possible?
Thanks for your help!
If I could answer my own question… The resolution is using Configuration API with RUM function Web application configuration API — Dynatrace Docs. More exactly RUM - Web application https://your_url/api/config/v1/applications/web/APPLICATION-UNIQUE_ID .
Hi @sorin_zaharov
Please check MONACO (MONitoring As COde) for automate the calls to those APIs
HTH
Yos
I know about it, but we’re looking at the easiest solution that doesn’t need any 3rd party solution. The API’s are enough. I just couldn’t find them from the beggining.
Stand corrected @sorin_zaharov
BTW IMO, Monaco is not 3rd party solution…its actually a dynatrace tool
Any how glad that you found out the solution for you API call issue.
All the best and stay safe
Yos
You’re right. I meant to say a solution that doesn’t need additional instalation/config.
Cheers!
