Migrating from Docker-only to generic container metrics in Dynatrace
Docker Inc, founded by Soloman Hykes, laid the foundation for cloud native computing. Built upon the Linux addition of LXC cgroups in 2008, Docker became the de-facto runtime engine for containerized workloads.
Today we have some alternative container runtimes to choose from including containerd and CRI-O, which use the Container Runtime Interface (CRI) as a standard way of integrating with Kubernetes. In 2019 the Kubernetes team decided to deprecate support for Docker, in favor or containerd and CRI-O, as it requires an extra translation layer (“shim”) for CRI support. Docker compatibility will continue through Kubernetes 1.22, expected later this year, though major cloud providers may end Docker support months earlier.
Seamless migration to containerd and CRI-O
Containerd and CRI-O support was enabled by default in Dynatrace environments created after v1.83 (fall of 2019). If you’re unsure of your environment’s birthdate, or you want to confirm a frictionless transition from the Docker runtime to containerd and CRI-O, navigate to Settings > Processes and Containers > Container Monitoring and enable both settings.
Important Dynatrace monitoring changes
As the industry shifts towards generic container metrics so will Dynatrace. Please walk through the following steps to avoid potential monitoring or alerting problems as Dynatrace begins its own deprecation timeline for Docker-only support, targeted at removal on January 1, 2022 September 2022. Please note, the deprecation will not cover container injection for automated deep monitoring of processes in Docker containers, but Docker specific container metrics and screens.
  1. Browse through the list of metrics in the table below.
  2. Communicate with your team that these metrics come directly from the Docker API, rather than from a generic place. Let them know that any dashboards, alerts or API integrations using these metrics must be modified.
  3. Let your team know the Docker screen in Dynatrace will be replaced by generic container views, and refer them to this article if they have questions.
Deprecated (Docker-only) metricGeneric container metric
Container bytes receivedbuiltin:containers.bytes_rx2builtin:tech.nettracer.bytes_rx
Container bytes transmittedbuiltin:containers.bytes_tx2builtin:tech.nettracer.bytes_tx
Devicemapper data space availablebuiltin:containers.devicemapper_data_space_availableNo generic container-level metric planned.
In K8s please use the PVC extension.
Devicemapper data space usedbuiltin:containers.devicemapper_data_space_usedNo generic container-level metric planned.
Devicemapper meta-data space availablebuiltin:containers.devicemapper_metadata_space_availableNo generic container-level metric planned.
Devicemapper meta-data space usedbuiltin:containers.devicemapper_metadata_space_usedNo generic container-level metric planned.
Container cpu usagebuiltin:containers.cpu_usage2builtin:containers.cpu.usagePercent
Container memory percentbuiltin:containers.memory_percentbuiltin:containers.memory.usagePercent
Container memory usagebuiltin:containers.memory_usage2builtin:containers.memory.residentSetBytes
Container throttled timebuiltin:containers.throttled_time2builtin:containers.cpu.throttledTime
builtin:containers.cpu.throttledMilliCores
Number of containers runningbuiltin:containers.no_of_containers_runningUse this expression:builtin:containers.cpu.usageSystemMilliCores:splitBy():count
Note: Metric expression can be used for the overall number of containers in an environment. Splitting by image is subject to further improvement.
Number of containers launchedbuiltin:containers.no_of_containers_launchedremoved
Number of containers terminatedbuiltin:containers.no_of_containers_terminatedremoved
Note: You can use Process Group availability settings to monitor if any process becomes unavailable or to define a certain threshold (e.g. how many process group instances must be available). Containers, which have been terminated unexpectedly, will impact Process Group (Instance) availability.
Number of containers runningbuiltin:containers.no_of_containers_per_pgiremoved
New generic container metrics in Dynatrace
Our migration to generic container support brings along a handful of benefits including new metrics in the data explorer, as well as container metrics in a number of different screens such as the workload view shown below.
great update @mreider
