Hi! I am planning to migrate from styled components to vanilla-extract styles, and I am not sure about the additional configuration for the DT app. I remember you were also planning to migrate back in January. Can you share the docs or information on how to use Vanilla-extract with the Dynatrace app? Thank you!
I can also recommend having a look at css-modules GitHub - css-modules/css-modules: Documentation about css-modules · GitHub
The only “setup” they require is a type definition:
e.g.: a css-modules.d.ts file containing
declare module '*.module.css';
assuming all styles will be stored in files ending with .module.css
