Mobile applications: Issues with Dynatrace .NET MAUI NuGet package
Summary
Having issues connecting your .NET MAUI mobile app to Dynatrace? This guide covers typical configuration errors, verification steps, startup instrumentation requirements, and platform‑specific fixes for the Dynatrace .NET MAUI NuGet package.
Failed build
If your build fails, make sure you’ve added the dynatrace.config.json file to the Assets (Android) or Resources (iOS) directory and that the file includes at least the beacon URL and the application ID properties. For details, see Configuration file.
If you use the manual startup, don’t include the beacon URL and the application ID properties in the configuration file. If you do that, you’ll encounter an exception.
Turn off Visual Studio Debugger for Android
If you notice that Dynatrace doesn’t report crashes for Android applications to your environment, make sure that you’re not using the debug option in Visual Studio.
  1. Right-click your Android project, and select Properties.
  2. Go to Android Options, and clear Enable developer instrumentation (debugging and profiling).
Keep in mind that clearing Enable developer instrumentation disables debugging. Use this option only to verify that crashes are sent. Optionally, you can create a release build that is detached from Visual Studio.
See also The start method for OneAgent is not valid in MAUI.
What’s Next
If you can’t resolve a problem with the Dynatrace .NET MAUI NuGet package for your mobile applications, please contact a Dynatrace product expert via live chat within your Dynatrace environment. Have the following details available:
Related articles
:open_book:  Instrument mobile apps with Dynatrace .NET MAUI NuGet package
:open_book:  The start method for OneAgent is not valid in MAUI
