Hi all,
Is there a way to configure HTTP repsone codes for a mobile application similar to services?
There is an implementation where HTTP 4** codes are used as business errors and should not be marked as failed requests and should not be taken into consideration for APDEX calculation.
Besides manual instrumentation of the entire application, could this be done from a configuration in Dynatrace or a simple config in the autoinstrumentation of the mobile app (iOS and Android both)?
Thanks for the answer!
