Hi
We are running Monaco 2.0 running against managed tenant version 1.270.96.20230711-145538. I’m able to download all Dynatrace Config entities like Dashboards, SLO, synthetic-monitor etc. except for management zones. Even the management zone folder doesn’t get created. No related error message pops up. Here is the only error message I get and it’s not related to Management Zones:
2023-11-30T21:59:17-06:00 error Failed to fetch configs of type ‘calculated-metrics-log’, skipping download of this type. Reason: Failed to get existing configs for API calculated-metrics-log (HTTP 400)! Response was: {“error”:{“code”:400,“message”:“You are using the new log monitoring solution. Old API endpoints are disabled.”}} (HTTP 400
{“error”:{“code”:400,“message”:“You are using the new log monitoring solution. Old API endpoints are disabled.”}}Here the the API list from the logs. I don’t see Management Zones listed:
2023-11-30T21:59:16-06:00 debug Default soft memory limit set: 2.1 GB2023-11-30T21:59:16-06:00 info Loading manifest “manifest.yaml”. Restrictions: groups=[], environments=[“Prod”]2023-11-30T21:59:17-06:00 debug Concurrent Request Limit: 5, ‘MONACO_CONCURRENT_REQUESTS’ environment variable is NOT set, using default value2023-11-30T21:59:17-06:00 info API can not be downloaded and needs manual creation: ‘kubernetes-credentials’.2023-11-30T21:59:17-06:00 info API can not be downloaded and needs manual creation: ‘credential-vault’.2023-11-30T21:59:17-06:00 info API can not be downloaded and needs manual creation: ‘extension’.2023-11-30T21:59:17-06:00 info API can not be downloaded and needs manual creation: ‘azure-credentials’.2023-11-30T21:59:17-06:00 info API can not be downloaded and needs manual creation: ‘aws-credentials’.2023-11-30T21:59:17-06:00 info Downloading from environment ‘https://xxxxxxx.dynatrace-managed.com/e/xxxxxxxxxxxxxxxxxxxxxxxxxxxx’ into project 'project_Prod’2023-11-30T21:59:17-06:00 info Downloading configuration APIs from 24 endpoints2023-11-30T21:59:17-06:00 debug APIs to download: - slo - calculated-metrics-application-mobile - custom-service-nodejs - calculated-metrics-application-web - synthetic-monitor - conditional-naming-processgroup - custom-service-php - service-resource-naming - conditional-naming-service - calculated-metrics-synthetic - reports - application-web - calculated-metrics-service - custom-service-go - synthetic-location - calculated-metrics-log - conditional-naming-host - dashboard - request-attributes - request-naming-service - custom-service-dotnet - application-mobile - custom-service-java - extension-elasticsearchThank you!
