Monaco Download based on tags
Hi
  currently i am download all synthetic scripts using Monaco Download. Is there a way to limit the download by tags or entity id’s ?
Attached is the manifest file that i am using.
<span>monaco </span>download --manifest prodManifest.yaml  --api synthetic-monitor --environment production-environment<br><br>#Manifest File<br><br>
<span>manifestVersion</span>: <span>"1.0"<br></span><span>projects</span>:<br>  - <span>name</span>: syntheticsScripts<br>    <span>path</span>: projects/synthetics<br><span>environmentGroups</span>:<br>  - <span>name</span>: production<br>    <span>environments</span>:<br>      - <span>name</span>: production-environment<br>        <span>url</span>:<br>          <span>type</span>: environment<br>          <span>value</span>: <span>"DT_Prod_URL"<br></span>        <span>auth</span>:<br>          <span>token</span>:<br>            <span>name</span>: <span>"DT_API_TOKEN"</span>
I would say no.
You can find here all flags available.
Best regards
Hi Anton,
    is it even not possible in manifest file, by using scope or any other parameters to limit the scripts.
thanks,
Avi
I am not aware of any way to do it.
Best regards
