Hi Team,
We are migrating Application monitoring from 1 DT Cluster to another DT cluster.
As per doc we can use Monaco for Configuration migration .
Anyone used Monaco for Configuration migration ?
Jalpesh
Hi Team,
Jalpesh
As you talking to migrate from Managed to SaaS?
Best regards
For Managed to SaaS, you can use also the app in the SaaS environment, see it in action -
For other uses, yes. It’s possible to some degree (that applies to Managed to SaaS use case above too). Monaco does not export all the configurations as some of the configuration APIs are not supported by Monaco. All configuration which are exposed using settings are possible, but configurations which are not part of the settings API and are not supported by Monaco must be performed manually or using the API manually. For supported configuration APIs, see the documentation.
Migrating configurations between Dynatrace environments is a project. It’s not just simple export/import task - this is possible only in smaller environments without deeper customization.
