Monitor Azure Data Factory Pipelines for Performance and Reliability
failedRuns = count(cloud.azure.microsoft_datafactory.factories.pipelinefailedruns),
succeededRuns = count(cloud.azure.microsoft_datafactory.factories.pipelinesucceededruns)
split by Pipeline
Is there a way to alert when the pipeline failed and close the ticket when its succeeded , currently we are alerting based on the failed runs which is creating alerts on concurrent failures , idea is to keep the alert open until there is a succeeded run
Hey @O11y_Noob ,
I just wanted to check in and see if you still need help with this. If so, I’d be happy to look into it for you! :blush:
this is still needed , it will be great if you can look in to this
Any solution for this ? we are facing the same issue in Dynatrace in Nov 2026. Failed pipeline runs closes eventually before it evaluates the succeeded pipeline runs
