Monitor Confluent Kafka Connectors with Dynatrace Extensions
Summary: This post discusses options for monitoring Confluent Kafka connectors in Dynatrace. It explains what metrics are exposed by connectors, how extensions can collect them, and limitations depending on each connector’s endpoint.
Hi, I want to configure “Confluent Kafka Connector” in the data explorer in the default “Confluent Cloud (Kafka) Overview” dashboard.
Does it support out of the box, or need to use the JMX metrics option only?
- Metrics to choose for this table
- Kafka connectors count, Dead Letter queues, Sent/Received records count
Status of Confluent Connectors (in other table)
- Status : Running/Stopped/Pause
Alert to send when Connector stopped
Please guide me to any document or steps to achieve this.
Thanks.
https://www.dynatrace.com/hub/detail/confluent-cloud-kafka/. (all available metric, content and features down below)
https://docs.dynatrace.com/docs/extend-dynatrace/extend-metrics/ingestion-methods/prometheus/prometheus-extensions#before-you-begin  (configuration)
I found this two documents hopes it helps :slightly_smiling_face:
Best regards
@Pawel_Zalewski  Can we collet confluent connector metrics through out of the box extension or not.
I have gone through one of the forum questions and still in confusion:
Solved: Monitor the Kafka connector & task status - Dynatrace Community
Can we integrate JMX extension with default Confluent Cloud (Kafka) Overview dashboard?
Please share the document how to integrate or collect JMX metrics for Connector through default Confluent Cloud (Kafka) Overview dashboard?
Can we collet confluent connector metrics through out of the box extension or not?
No we can’t, this is planned but not yet implemented
Also no unfortunately
I was looking for it and didn’t find anything. Only docs i found was this wich i’ve already post above.
Best Regards
