Hey,
We want to be able to see the status or events we had on each deployment, I know that Dynatrace can provide this service like in the link below:
Can someone here advise how can we get this feature?
Also, if there is a better way to receive what we are looking for, I would be happy to hear.
Thanks!
Hi @YuvalKonstanti
you basically have a few options to leverage the releases feature:
envionrment variables that you can provide to your processes/application code
custom deployment events that you push to your environment (e.g. through your CI/CD pipeline)
Both variants are described here:
kr,
Reinhard
I have implemented this feature nicely in our environment and all API worked perfect to push the right version on each process deployed. I am currently integrating it with our deployment pipelines.
I share this API call to help you, you need to create an ingest token and a tag to precise your process groups
The JSON that I used in this example:
“eventType”: “CUSTOM_DEPLOYMENT”,
“title”: “PerfServlet Release”,
“entitySelector”: “type(PROCESS_GROUP_INSTANCE),tag(Application-Functionality:PerfServlet)”,
“properties”: {
“dt.event.deployment.name”:“PerfServlet”,
“dt.event.deployment.version”: “8.5”,
“dt.event.deployment.release_stage”: “PROD” ,
“dt.event.deployment.release_product”: “perfServlet”,
“dt.event.deployment.release_build_version”: “5”,
" dt.event.deployment.project": “IBM”
EPL
March 7, 2024, 1:42pm
4
Thank you Marwan it was very useful.
