I’m not sure how I can do this about Database. Appreciate pointers from the Gurus here.
FYI, we have many DBs in a MS SQL servers. And there are plenty of tables in each DB.
My interest is only on 2 tables.
I would like to be able to view a DB table’s growth such as how and when data was added or deleted over a period of time.
I wonder how can I do that?
Note: Currently we do not use activeGate anyway.
I would say creating your own extension where you execute SQL queries or logs. But you would need an ActiveGate.
Best regards
Hi AntonPineiro, I believe what you mentioned is similar to this SQL data source — Dynatrace Docs ? It involves creating extensions, SQL server config including activeGate and SSL?
Hello @cleoleeps1
PFA options regarding the raised concern:
You can also build your own Extension as highlighted by @AntonPineiro
The third option:
- Contacting Dynatrace Extensions team for developing the required extension “Professional paid service”
All the best &&Hoping it helps.
BR,
Peter
Yes, if official SQL extension does not provide you that information. We can create your own.
Best regards
