we have below xcom running in Linux env. but it is not listed as process under the host.
How do we monitor this in dynatrace?.
Hi @sundarv1
Please check Which are the most important processes? to understand why your process is not monitored OOTB.
Dynatrace provides the option of monitoring specific processes that is not mark as important process.
HTH
Yos
Hi Yosi
Xcomd process is running in the server and but it is listed in the host level process.
I did do the declarative process grouping and but it is not work.
Could you please provide screenshot how to configure my xcomd in the declarative procees
Hi Yosi
I am taking about unix process monitoring. not java monitoring. Please find attached steps which i did and but it is not working.
Declarative Process.docx (45.8 KB)
Remember those changes will be applied when you restart process.
Best regards
