I want to know if someone has ever monitor a remote tomcat server using JMX.
My problem is that I can’t install a Dynatrace agent on this server and the available extension seem to only works with installed agent.
I know this is possible with Zabbix who’s working with a java gateway to pull the data so I want to know if someone already try to do something like that for Dynatrace.
In this case you should create your own Tomcat JMX extension which would run on the Dynatrace Environment Active Gate to collect the jmx metrics remotely.
