Hi everyone,
Our client needs to monitor a log, where the only thing he needs is to know if the log was written or not, among 5 minutes. If the log didn’t receive any input in 5 minutes, Dynatrace should alert or show a number (probably 0) in red in a dashboard.
I was wondering if somobody could help me with this request, please.
At this moment the log is already ingesting in Grail.
Hi @Raul_CL,
Maybe it is not the perfect and clean solution but I thnik it can be use in Managed and Saas also.
I would create log meteic like this: Count the log lines with the dimension of log.source. About this metric you could create a table dashboar tile split by log.source. You can set a 5 mins filter to the table and you can colorized the thresholds…
And If you want an problem notification aslo then you shouls create a metric event from log.line.count like this:
I have not tried it, it is an idea. Could you please check it? Please consider the DDU consumption of the log metric.
I hope it helps.
Best regards,
Mizső
Thank you very much Mizső. Your idea worked perfectly.
Great workaround @Mizső !!!![]()
