I want to install OneAgent on the Active Directory service HOST built on AWS EC2 to monitor the Active Directory service. So I tried setting up the extension “Active Directory services”, but the Status is displayed as “PENDING” and I cannot monitor it. Is there a problem with the environment?
Hi @Shirai , could you please check if you have the Extension Execution Controller is enabled?
Hi @p_devulapalli -san.
I have enabled “Extension Execution Controlle” and can now monitor it.
Thank you.
Toshimasa Shirai.
