Monitoring APT updates
Do you know if Dynatrace is able to check apt updates pending? This is only related to GNU/Linux machines with Debian/Ubuntu distros using APT package manager.
I think it is not possible directly by OneAgent but I am not sure if a extension exists.
Thank you in advance.
Best regards
@AntonPineiro,
Never heard anything related to that. But it would probably be easy to do it with an extension. Even maybe integrate with the appsec offering.
A Product Idea might be a good idea here. If so, please link here so it can be upvoted.
Thank you @AntonioSousa, this has been raised APT updates.
Best regards
this is marked as a solution. The linked idea is not accessible though …
Regards
Hi @Michal_Gebacki ,
Maybe this product idea is hidden also. It would be insteresting to know which product ideas have been hidden.
Thank you again!
Best regards
