Monitoring frontend application hosted in AWS S3
I am trying find out does Dynatrace monitor frontend application hosted in AWS S3? If yes, is there any dashboard that shows which AWS S3 instance hosting which front end application?
Thanks.
I’m not really an AWS S3 guru, but I guess you will upload some static html files. You can create agentless real user monitoring applications within Dynatrace and then put the JavaScript snippet into your html files before uploading them to S3. This will enable real user monitoring for these applications.
