Monitoring IBM MQ
Can DT monitor IBM MQ running on a AIX host?
Thanks in advance.
Hi @ssamraj
Yep, with IBM MQ ActiveGate extension
HTH
Yos
Thank you @Yosi_Neuman . Got baffled after just checking IBM MQ oneagent extension alone.
Can it monitor MQ 8.x?
Hi @ssamraj
According to other documentation this version is supported via AG extension
May be this is a new extension version that was not test against MQ 8 because it is marked as EOL ?!
I would give it a try any how.
HTH
Yos
Thank you @Yosi_Neuman . Strange to find out why there’s no mention about IBM MQ 8.x in Extensions — Dynatrace Docs
True, the docs list IBM MQ 9.x+.
We have several customers using it with 8.x, but as it is no longer supported by IBM we no longer test with that version and cannot guarantee that it will keep working.
I will ask that it is updated on the general supported version page as well.
Mike
