Monitoring Kafka consumer lag using JMX addon
Hello.
I am trying to monitor consumer lag of Kafka in dynatrace and have some problems. If anyone has successfully started monitoring this parameter, can you give a link or provide me an example of the working jmx plugin for monitoring consumer lag of Kafka?
It is needed for Kafka server
I’m interested if you succeeded in monitoring the consumer lag
Hi @Chrisdc @ksverchkov
Here is an example from a test system about one consumer’s lag:
I hope it helps.
Best regards,
Mizső
