Monitoring mode for PaaS/Standalone deployments.
Any mechanism to change monitoring mode for PaaS/Standalone deployments after the OA deployment?
Tijust
PaaS agents do not have any monitoring modes you can choose from.
@Julius_LomanThanks for your response. So, just to confirm, the default setting is Full Stack and there’s no option to switch between different stack types, even when using the OneAgent command line, correct?
@sujit_k_singh PaaS deployments do not have the oneagentctl command line utility. There is just full-stack and only for processes loaded with the PaaS agent. You won’t see other processes running in the operating system.
@Julius_Loman Ahh i dint know this… thanks a lot for clarification.
Hi, @Julius_Loman How do I determine if a host is part of standalone/PaaS deployment? By looking at the missing monitoring mode in Dynatrace UI?
@SrikanthSamraj you can see it in Deployment status for example as Monitoring mode:Standalone/PaaS or you can filter these hosts also on the host classic page and using monitoring mode filter.
