monitoring obsolete version of operating system
Hi all.
We have a client with some servers in Linux RH 5. There is some way to monitor them, for example some infrastructure plugin …
thanks
Jose A
Technology support — Dynatrace Docs says:
RH 5.4+ is supported with disabled SELinux
I would give it a shot with the Oneagent, If you have an older version you could even give that a shot. If those options fail you could always try agentless monitoring. Its worth a shot, it might work and it might not.
thanks Chad, is there any documentation abaout this?
install agentless, configuration,…
besta regards
jose A
yes there is, Here is a great tutorial on how to set up an Agentless Monitored Device (AMD):
https://www.dynatrace.com/support/help/how-to-use-dynatrace/real-user-monitoring/setup-and-configuration/web-applications/initial-configuration/set-up-amp-monitoring/?_ga=2.83276181.2056593655.1581684865-69792766.1581684865
but this AMD is part of DCRUM/NAM not dynatrace !
@Rastislav D. Ano
I can confirm. We do have a customer running RH 5.x, even the uncommon 32-bit version. It is supported with disabled selinux and with appropriate version of glibc that comes with RHEL 5.4+
