Hi everyone,
I’m trying to set up availability monitoring for our Palo Alto firewalls in Dynatrace, and I could use some guidance.
So far:
- I don’t see a built-in Palo Alto availability metric in Dynatrace.
- As a workaround, I created a custom metric based on CPU System Utilization and set an alert on missing data (with adjusted violating samples).
- This works in the sense that I get alerts when the metric stops reporting.
However, our dashboard also displays another metric, System Uptime, which shows that the device has been up for X days. In a few cases we received “availability” alerts from the custom metric, but the System Uptime value clearly indicated the firewall was never down—so the two signals contradict each other.
Questions:
- Has anyone implemented a cleaner way to monitor Palo Alto availability in Dynatrace?
- Is it possible (or recommended) to leverage the System Uptime metric itself as the source for an availability alert?
- Any best practices for correlating missing-data alerts with uptime so we don’t get false positives?
Appreciate any suggestions or examples of how you’ve tackled this!
Thanks in advance,
