Hi all.
The rabbitmq monitoring prerequisites Timedrift Monitoring extension — Dynatrace Docs
indicate:
- A single RabbitMQ cluster
Why is that so?
thanks in advanced.
Jose A
Hi all.
indicate:
Why is that so?
thanks in advanced.
Jose A
You have to have agent installed on RabbitMQ host to enable this plugin. In such case it can connect to only single instance per host. If you have 5 hosts with rabbit mq with agent available on all of them you can monitor all instances.
