MountVolume.SetUp failed for volume "oneagent-bin"
Hi, i have this error in the installation of the agent on k8:
Warning  FailedMount  100s (x15 over 16m)  kubelet            MountVolume.SetUp failed for volume “oneagent-bin” : kubernetes.io/csi: mounter.SetUpAt failed to get CSI client: driver name csi.oneagent.dynatrace.com not found in the list of registered CSI drivers
can anyone help me please?
@kevin_ortiz Can you please confirm which Dynatrace operator version your using?
I think there was bug in Dynatrace operator 1.2.0, If your using the same version you can update to 1.2.2
Hi @VenkataSainath , i have the last version available 1.3.2, i put here the output of the operator:
[root@SRV-K8S-M2-PRE ~]# kubectl exec deploy/dynatrace-operator -n dynatrace-pre -- dynatrace-operator troubleshoot
{“level”:“info”,“ts”:“2024-11-26T21:49:12.090Z”,“logger”:“version”,“msg”:“dynatrace-operator”,“version”:“v1.3.2”,“gitCommit”:“11b12492182e1f5b896adb4e9feb070373b1865c”,“buildDate”:“2024-10-24T11:00:21+00:00”,“goVersion”:“go1.23.2”,“platform”:“linux/amd64”}
{“level”:“info”,“ts”:“2024-11-26T21:49:12.090Z”,“msg”:“logging level”,“logLevel”:“info”}
[oneAgentAPM]   --- checking if OneAgentAPM object exists …
[oneAgentAPM]    ✓  OneAgentAPM does not exist
[namespace ]    --- checking if namespace ‘dynatrace-pre’ exists …
[namespace ]     ✓  using namespace ‘dynatrace-pre’
[          ]    no Dynakube specified - checking all Dynakubes in namespace ‘dynatrace-pre’
[crd       ]    --- checking if CRD for Dynakube exists …
[crd       ]     ✓  CRD for Dynakube exists
[dynakube  ]    --- checking if ‘dynatrace-pre:cluster-pre’ Dynakube is configured correctly
[dynakube  ]        using ‘dynatrace-pre:cluster-pre’ Dynakube
[dynakube  ]        secret token ‘apiToken’ exists
[dynakube  ]        checking if token scopes are valid
[dynakube  ]        token scopes are valid
[dynakube  ]        checking if can pull latest agent version
[dynakube  ]        API token is valid, can pull latest agent version
[dynakube  ]        pull secret ‘dynatrace-pre:cluster-pre-pull-secret’ exists
[dynakube  ]        secret token ‘.dockerconfigjson’ exists
[dynakube  ]     ✓  ‘dynatrace-pre:cluster-pre’ Dynakube is valid
[dynakube.imagepull]    --- Verifying that OneAgent image Login - Dynatrace can be pulled …
[dynakube.imagepull]     ✓  OneAgent image Login - Dynatrace can be successfully pulled
[dynakube.imagepull]    --- Verifying that OneAgentCodeModules (custom image) image  can be pulled …
[dynakube.imagepull]        No OneAgentCodeModules (custom image) image configured
[dynakube.imagepull]    --- Verifying that ActiveGate image Login - Dynatrace can be pulled …
[dynakube.imagepull]     ✓  ActiveGate image Login - Dynatrace can be successfully pulled
[dynakube.proxy]        --- Analyzing proxy settings …
[dynakube.proxy]         ✓  No proxy settings found.
Hi @kevin_ortiz
First of all you have to determine the current K8s deployment, is it the accurate method as per Dynatrace best practices and the actual setup or Not:
PFA Dynatrace related resources for detailed level of troubleshooting:
Entry Point to K8s:
The recommended approach:
Simply:
  • If the CSI Driver has been installed with issues, you can uninstall and re-install it again as per the attached resources, it’s easily configured on K8s.
Hoping it helps.
KR,
Peter
Hello @kevin_ortiz
  • It’s recommended to keep the monitoring components “Cluster Nodes, OneAgents, AGs, Operator” up to date.
  • Ensuring the target technology is supported by Dynatrace and updated.
  • Feel free to review the troubleshooting guide: Monitoring issues troubleshooting — Dynatrace Docs
  • In such cases it’s better to simulate the case entirely on development environment, uninstall the Operator and related components, remove all related directories from K8s && conduct a clean K8s integration it will succeed.
Peter
I’m not sure if this is your issue, but we also had this error when we switched from cloud-native full stack to application monitoring. The version we had specified for cloud-native was in the format <major>.<minor>.<release> but application monitoring was expecting <major>.<minor>.<release>.<timestamp>.
