I have a Dynatrace installation (PoC - Proof of Concept installation), and in next dates we will have a new Dynatrace Installation (we can say Production Installation)… So how we can move with less effort current monitoring configuration (dashboards, alarms, tags, etc.) from PoC installation to the new and final Production installation ?
Please we really appreciate guidelines, best practices and automation tools for moving from PoC Dynatrace cluster nodes to Final Production Dynatraace cluster nodes.
Target is recreate configuration with less effort and risks.
I’m working on such tool right now, it will still take some time because of lacks of time for that project. But in general, the only you can use right now i Configuration API:
When we are doing POC’s in most cases we are creating server that will handle production after presales. In such case we just change license into production one and we are ready to go.
We had the same scenario going for our POC to purchased instance. You can fiddle around with the API if you’d like and saving the json payload for each dashboard and the settings ETC. my Professional recommendation would be to create a cluster backup. You will need to get a hold of a support rep to assist you with restoring from the backup. But since you just completed the POC the sales rep should be able to get you in contact with the right person. It is important to note, that the back up is for settings and configuration only, your user data and such will not be carried over.
we (amasol) are currently working on a solution that will cover your use case.
Currently we plan to cover three main use cases with the solution:
Config Backups
Easy Configuration Management
Continuous Configuration Management
Config Backups
The dynatrace managed backup mechanism is intended for disaster recovery. There is no way to do fine grained restoration of specific configuration.
We solve that issue by doing continuous backups of the dynatrace configuration to a git repository.
We want to make it easy to copy configuration between different tenants, environments or even inside them. This will make it possible for example, to copy config over from PoC environment or to copy configuration between the different stages of your applications.
Via a web UI it will be possible to copy configuration or restore it from a backup.
For the last iteration we plan to enable customers to integrate dynatrace configuration updates into der CI/CD pipelines. With this you can deploy new dynatrace configuration directly with your application over different stages, simply with an API call.
Use case one (Backups) is already implemented and currently being tested by different customers. The Easy Configuration Management is the next step on our roadmap.
Once the second use case is finished, we plan to offer the solution on the dynatrace marketplace.
If you want more information or have feedback please let me know!
Currently the simplest way is to import the dynatrace configuration API spec.json into Postman as a collection, and then create different postman environments for the dynatrace environments.
It’s still a lot of manual work, but it makes it a lot shorter then manual copy/paste
We plan to offer this as a SaaS Service for customer of our aMC Plattform, Dynatrace SaaS, and Dynatrace Managed customers where the cluster is available from the outside.
We will also offer a self hosted version that can be run on a VM or deployd as a container. This will then also work for closed off Managed or Offline installation.s
Our solution is very easy to use. You can install it within a few minutes, backup the Dynatrace configuration and use it for the restore on the new environment.
