Hi @Mike_L
What are the differences between the two local MS SQL extensions?
Monitor SQL Server using OneAgent | Dynatrace Hub
Microsoft SQL Server local counters monitoring & observability | Dynatrace Hub
Thanks in advance.
Best regards,
János
Hi @Mike_L
Thanks in advance.
Best regards,
János
You were quick to spot it! :grinning_face:
The first one will be removed in the next day or so. It was based around the WMI data source and could cause a large CPU overhead on the server. The new one is based on the Python data source and is closer to what we used to have in extension framework 1.0.
Hi @Mike_L ,
Thanks for the calrification. Yes, I can see in the attached picutres that it is a python extension.
To be honest I am continously “monitor” the new extensions day by day :wink::
Best regards,
János
