Multi-node setups for failover and data redundancy
In the documentation, I read that recommended multi-node setups for failover and data redundancy is 3-node cluster.
Anybody has idea why it isn’t two, but 3? Isn’t two-node cluster can already cater for that?
Best Regards,
Wai Keat
With 2 nodes you can’t guarantee aspects such as partition tolerance. Two-node clusters are typically feasible only in active-passive setups (speaking generally).
If I recall correctly this is due to the replication of the cassandra cluster which needs three nodes for a high availability setup.
To fully understand this concept you need to know what is a primary node in cluster.
Majority of things that cluster nodes do can be done by any of them - e.g. processing data from agents, preparing data for charts, filtering logs and so on. Any node in any moment can perform these tasks so in case of node being down, other node can do the processing instead.
However, there are few tasks that need to be done only on one node (like cluster scalling management, billing calculation, updates management). Node which do these things is called primary and is chosen autmatically by “leader ellection” algorithm.
If primary node for some reason goes down, after a while other nodes will recognize this situation, they will choose new primary and cluster will work correctly.
So far so good, everything seems fine even for 2 nodes cluster: if primary goes down, second node becomes a new primary and can do tasks “primary tasks”.
Unfortunately there is one scenario that’s more difficult than “node going down” - network problem. In three nodes (let’s name them A, B and C) cluster in normal situation all nodes can communicate each other via network.
When connection to node A is broken, we’ve got cluster split into two parts: B+C and A. B and C can still communicate.
Leader ellection algorithm allow two choose the primary node only if cluster node can communicate to more than half of cluster nodes (including itself). Nodes remembers that their cluster size is 3. In this case primary will be chosen out of B and C nodes (B can communicate with B and C which is 2/3 of all nodes, the same is true for node C, while A sees only itself).
If cluster consists only of 2 nodes (X and Y) then after network failure X can communicate only to itself, the same is true for Y. No node can be chosen as primary because 1/2 is not more then half.
Now we’re close to conclusion. You may ask why we use the rule of being able to communicate to more than half of cluster nodes. If we don’t apply that rule, in second scenario both nodes X and Y may “think” they’re primaries (both “thinks” that other node is down) and start performing primary-only tasks which can lead cluster to go into corrupted state.
Please notice this is common feature of clustered software. I mean the same is applicable for Cassandra, Elasticsearch (both are used by Dynatrace cluster) and many others.
