Multi-window multi-burn SLO
Hi there,
Has anyone implemented a Multiwindow Multi-burn SLO( as found in Google’s SRE workbook) using the SLOs App?
It looks like the only way to get multiple windows and burn rates is to create a custom workflow.
Thanks George
Hi @g_kat,
A custom Workflow may not be necessary for the burn-rate evaluation itself. Dynatrace officially recommends using DQL-based custom alerts to monitor SLO error-budget burn rates: Service-Level Objectives - Dynatrace Docs . An interesting alternative is to use records-based custom alerts, which support aggregated metrics, custom query timeframes and complex DQL filtering. Anomaly detection.
Paweł
