Multiple Dynatrace Managed instances on the same environment
I would like to know if we can have two separate instances of Dynatrace Managed running on the same Environment. My customer would like to have their own instance whilst the hosting provider will have their own. This is Due to licensing restrictions, the customer can not access the hosting providers instance of Dynatrace Managed but they are willing to purchase their own licence to have visability to the system
you can’t install 2 oneagents on one hosts. Single oneagent also doesn’t have possibility to send data to 2 dynatrace managed instances. You can always talk with your hosting provider about giving them vpn access to your dynatrace instance, or consider SaaS version. Than there will be no problem with giving them access to this environment.
Thanks for the answer Sebastian
