MySQL Process Unavailable
MySQL process unavailable alert is created but when database team checked process was running fine. In Dynatrace process group MySQL two processes with same name but one is available and another is not available.  May i know why this alert was generated and two processes with same name but one is available and another is not available.
Hi @Jivan
Can you please send a screen shot of what your configuration looks like for the problem?
Radek
Hi @radek_jasinski Do you want to see problem card or settings for problem?
settings:)
My guess is that there should be the cluster configuration of Active and Passive. If those nodes are different then seperate them from management zone or host group. After doing that it will show you the data as you wanted.
Hi @Jivan
Have you managed to solve the problem? It would be great if you shared the solution with the Community users :light_bulb:
