We are working on POC for Log monitoring in SaaS. I am facing issues with log traces and span ids. I am unable to navigate between logs and session replay.
Log to trace and user session to request are two different links. Log to trace is based on trace context information,
user session to trace is based on x-dynatrace headers (mobile/custom apps) or cookies/x-dtc headers (web applications).
If you have see the dt.trace_id in your log, you should be able to open the trace (if it’s captured).
