Navigation link to Problems App.
Hello.
I’m trying to include a navigation link to Problems App. From Problems App documentation the only intents available are view-problem and view-problems-add-on. None fits my requirement, because I want to navigate to problems list with a predefined filter.
This is my code:
<Link
href=‘/ui/apps/dynatrace.davis.problems’>
But it does not work.
If I try to open in another tab this is the url it opens:
https://{environmentid}.apps.dynatrace.com/ui/apps/my.app/apps/dynatrace.davis.problems
Hi Jose,
Are you talking to have some links as that?
Best regards
Hey,
For a simple link to an app use getAppLink from the navigation SDK: Navigation | Dynatrace Developer
Hope that helps!
Cheers,
David
If you’re using it in a DQL query, (replace {{ENVID}} with your environment ID):
| fieldsadd problemURl = concat( “[”, display_id, “](https://{environmentid}.apps.dynatrace.com/ui/apps/dynatrace.davis.problems/?filters=%22Alerting+profiles%22+%3D+Jira)”)
You can customize the filters as needed—just make sure they’re properly URL-encoded.
Finally, set the column type to Markdown so the link is rendered correctly.
