network connectivity
Hi All,
I have a question, why does the network have less than 100% connectivity? What is the reason?
AskmeTeam
Monitor network communications — Dynatrace Docs → look here:
Connectivity Percentage of properly established TCP connections compared to TCP connections that were refused or timed out.
Note: The Connectivity measure can be used as an indicator of whether there’s network traffic on a host. Note, however, that 0% connectivity doesn’t necessarily indicate that there is a problem with a host. Assuming no TCP errors are present, it may simply mean that no users have attempted to connect to the host process during the selected timeframe.
Information from documentation.
My host is not idle still both nodes showing 15-20% of Connectivity please suggest the issue.
My host is not idle still nodes showing 15-20% of Connectivity please suggest the issue.
I would suggest talking to network colleagues, and you can raise a support ticket in Dynatrace ONE also.
Best regards
Is the a network issue or Dynatrace configuration?
You can run OneAgent diagnostics, it collect host information. It can be useful if you raise a support ticket.
Best regards
