New variant values for Strato button
With the recent release of @dynatrace/strato-components-preview version 0.92.1, there were introduced breaking changes to the Button component i.e. variant prop. The migration script replaced only part of the old values, thus I have to replace the rest manually.
How do the new values (“default”, “emphasized”, “accent”) correspond to the old ones (‘primary’, ‘secondary’, ‘minimal’, ‘critical’)
the design system team replace every minimal with default and for the rest:
* primary → default
* secondary → emphasized
* critical → accent
I would recommend to use the same approach.
The transition you provided is a bit different from what the migration script (partly) did i.e.:
  • primary → accent (and color “primary”)
  • critical → emphasized (and color “critical”)
Shouldn’t I trust the migration?
You are right I just looked up the minimal → default mapping, because this looked confusing.
I’m sorry, but I’m not sure if I understood correctly. If I would follow the transition rules for the “variant” prop:
  • minimal → default
  • secondary → emphasized
Would it be correct? Could you please confirm (or not)?
I followed up on that again and yes I can confirm exactly that.
