Nexthink integration
Hello dears,
Is there an integration between Dynatrace and Nexthink.
Thanks.
Not that I am aware of, but I’d be curious as to what type of integration you are looking for @Peter_Youssef? Essentially what is the goal/function of the platform you are looking to link to - do you want data ingested into Dynatrace or export the Dynatrace data to a 3rd party.
These contexts matter in order to fully understand the overall goal and possibility route.
Hi @Peter_Youssef I’d also like how do you scope and integration like that (what are your desire for an integration between the two platform).
I was asked the same 2 days ago and I started to read about Nexthink
Hi @Peter_Youssef, I’d also like to understand your motivation for this integration.
Maybe there is a possibility to use this Nexthink module HTTP API Exporter | Nexthink Documentation and the Dynatrace API (e.g.; POST /metrics/ingest) to exchange data between Nexthink and Dynatrace.
I don’t know if an additional integration is required. And with the newly announced NexThink flow module it should be much easier to exchange data between both platforms.
I would also be interested in sending Nexthink metrics to Dynatrace. This is a potential to address issues raised by the change in support of the browser extension monitoring.
Hi all, Nexthink released a new webhook functionality and already collaborate with Splunk for an OOTB integration.
I created following new product idea to bring this to Dynatrace’s product management awareness.
Maybe vote for it to increase the visibility of the idea.
Hi @ChadTurner , @y_buccellato , @Bill_Demsky  appreciate your time & efforts following up with the raised concern and kindly accept my apologies for late responses.
Hi @StefanSchwarz
Thanks for sharing valuable feedback, it’s the exact requirement.
BR,
Peter.
