Hello community.
Customer has nginx-plus-r18 and NGINX successfully have been instrumented. We have services for this process. But there is the warning:
Anybody knows what does this message mean?
Alexander
Did you checked Support Archive logs from agent. Most of the time there is some extra explanation. I’ve never faced so far such message. Maybe support will help here. One more question, do you have any custom plugin that is named nginx status? Second question, those services are WebRequest services or opaque ones? If Opaque, you in general do not see transactions measured on nginx itself but representation of request that is coming from different service.
Hello Sebastian,
1) I also check log files and there is no errors\exceptions on it.
2) No there is no additional plugins.
3) It is not OPAQUE service. I have see service calls.
Alexander
Hi Alexander, what agent’s version do you have ?
Don’t you have anything in the log like
info [native] Configuring nginx plus metrics plugin with url ‘http://ip:port/status’
Did you download support archive that is covering timeframe since starting this process (with this communication). I’m asking because be default support archive is for one day I think.
I have same results with archive for 7 days for search "errors/nginx plus/status and e.t.c. I will try explore more attentively later.
I have second same server and there is no such message. I think we need restart this process. Already planned.
Alexander
Try restart and read logs right after restart. You will see dedicated log for Nginx process. It should start new file after restart so read it carefully. Looking on them by search function isn’t best idea because you can miss multiple things.
NGINX plus provides exposes additional metrics, which OneAgent tries to capture. Dynatrace will show you this message in case the metrics cannot be accessed. For R15 and earlier you had to enable the NGINX Plus Status page to make them available. With R16 and later they switched to an API that needs to be configured. Unfortuntely R18 had a breaking change in the API which is currently not supported. OneAgent will support R18 metrics with version v177.
Best
Patrick
Patrick, thank you for detailed answer.
Alexander
Hello I am facing the same issue . We have updated One Agent and Active Gate to 1.331 versions.
Error message : "
Nginx Plus monitoring is available! To enable, please configure the Nginx status plugin."This is the config in the .values
nginxStatus: enable: true port: 8080
nginxplus: true enableOIDC: true enableCertManager: false enableCustomResources: true
